GALVANIC CORROSION IN 7075 ALUM
hAVING PROBLEMS IN A CNC MACHINE WITH THIS WOULD COATINGS ON THE TOOL HOLDERS WORK TO PREVENT THIS? uSED ZINC IN THE COOLANT STORAGE AREA WITH ON AVAL.
RE: GALVANIC CORROSION IN 7075 ALUM
Try anodising the part that is corroding.
Determine the PH of the coolant solution that is probably acting as an electrolyte and alter it to a range between 4 and 9, this may help.
