Choke size for Gas Wells.
Is there a formula that can decide what is the best choke size for a gas well? We have 5 pumping routes with atleast 40 wells each. I am a floater which means every couple of days I am running a different route. Every pumper has a different Idea about what choke size to use.
RE: Choke size for Gas Wells.
John
Hopefully (!) the caculated FWP from downhole will be higher than the pressure from the separator....the difference between the two is the pressure you want to drop across the choke.
Take this pressure (and the flowrate), plug it into the bean sizing software mentioned above, to get an idea of the bean size required.
