Ball valve 1/2" and 1 1/2" class 4500
Hi all.
For a valve test bench we are looking for ball valves to be installed in the filling pipes with as big as possible open flow path.
They should be 1/2" and 1 1/2" class 4500 to cover 600 bar operating pressure, fluid to be water and air/nitrogen, bubble tight sealing, threaded ends, materials as per manufacturers recommendation.
If possible somewehere in Europe? I have asked a lot of manufacturers but not one could offer a solution.
Does anyone have an idea?
RE: Ball valve 1/2" and 1 1/2" class 4500
http://www.jareckivalves.com/products.html
Here are the PBV valves. The make a lot of gas valves.
http://www.zy-tech.com/site_frame.html
Other manufacture that offer high pressure ball valve could be like www.habonim.com manufacture from Isreal, even though it is not shown on their homepage, they might be able to offer a special solution...Ask for Chaim Schwartz.
J. Alton Cox
www.delucatest.com
Bobby Corte Jr.
Phone 985.223.1966
Fax 985.223.1936
Cell 985.209.3061
[bcorte@uscortec.com]
J. Alton Cox
www.delucatest.com
