Stacked Vessels
Stacked Vessels
Can someone please share their experience on designing stacked pressure vessels? Besides subjecting the lower vessel with the weight of the upper vessel, nozzle alignment/loading issues, shimming requirements, local load analysis of the lower vessel shell (which supports the weight of the upper vessel), etc. etc. are there another other design headaches that come with this?
Has anyone here designed and installed stacked vessels before? Would you still do it if other alternatives exist?
Thanks in advance. (b.t.w., A516 70 mat to Div 1, offshore application)
Thanks in advance.
Thanks in advance.
RE: Stacked Vessels
RE: Stacked Vessels
RE: Stacked Vessels
STE03360 - Heat Exchanger and Horizontal Vessel Foundation Design Guide.
Please explane how or and tehnical reference artical for Thermal expansion of intermediated
nozzles:
The approach theory is that a heat exchanger stacked is moving differently on the saddle due to thermal expansion and intermediated nozzles have stress to maintain shape.
Need the Team membeer Help:
Know how much force is operating on nozzles and the nozzles can end up with stress.
RE: Stacked Vessels
RE: Stacked Vessels
NozzleTwister
Houston, Texas
RE: Stacked Vessels
Comments would be appreciated.
