I need to know what MPFI means.
i want to know what does MPFI stands for?
RE: I need to know what MPFI means.
Multiport fuel injection.  A fuel injection setup where each cylinder gets its own injector (and the injectors inject directly into the ports, rather than somewhere upstream).
hi
i m a RECK STUDENT
WANT TO KNOW EVERYTHING ABOUT MPFI
HELP ME
MPFI is MULTI-POINT FUEL INJECTION(Note that CART V8s inject alcohol into the air horns,not the ports). TBI is THROTTLE BODY INJECTION. These systems are really only PRESSURIZED CARBURATION.By actual definition,FUEL INJECTION is the introduction of fuel DIRECTLY into the cylinder/chamber. Happy New Year!
Come on , guys. Crack open the text books, you will be the better for it.  If we do your homework, you won't learn nearly as much as you would by doing it yourself. Besides the fact that you will pick up all sorts of interesting data along the way.
Rod
