Printing Multiple views in a layout
hi all
  Does anyone know a lisp or a tool i can use to print multiple views in a layout with print settings i determine?
of course i do not want to select each view from the plotting window.
i want it to be automated process
RE: Printing Multiple views in a layout
Hi Dawn,
It would help if you could tell us which version of AutoCAD you're using - it will be a lot easier with the later revisions...
i use Autocad 2005
  I really don't have enough information from you to answer... but here is a guess;
  Perhaps you are unaware you can create multiple viewports on a layout.  Also, you can create multiple layouts, each with a custom set of views.
Joe Dunfee
