Autocad 2006 Express Menu
Hi all
  i have installed Autocad2006 with express tools, i can use the Express tools only throught the command line, and also i can not find the express menu or the express toolbar
what can i do?
RE: Autocad 2006 Express Menu
Type Menu or MenuLoad, then find the express menu on your hard drive.
Thanks IFRs so much i have loaded the express menu, but now it is after the help menu how can i move it to be before the help menu.
lol i loaded the express menu and all the others disappear.  its an 'either or' type of deal.  im running 05 on xp.
Choose menuload to load the autocad and the express menus
each one has a diffrent menu file. and when you use the menu command you can only load one of them.
type EXPRESSMENU at the command line. The "express" tab will move to before the "window" tab
during a search of the pc ... express.mnu is not found but if you follow "nalayruf" s suggestion of typing EXPRESSMENU IT WILL APPEAR
