Mathcad/AutoCAD Images
I use Mathcad 7 and AutocadR14 (and now 2002). I used to cut and paste images from AutoCADR13 into Mathcad6 and they looked decent with a white background. In Mathcad7 and R14 they came in with a black background.
Basically, I want to include my AutoCAD sketches in my Mathcad documents with as little trouble as possible. Does anyone have any suggestions? Does the newer Mathcad versions fix this?
RE: Mathcad/AutoCAD Images
1. Insert an object.
Insert an AutoCAD object, create it from a file and link to the AutoCAD drg you're using. Otherwise Create From New.
2. Copy and Paste
In either option, to save changing the colours create a new layout with a monochrome setting and 'Show Plot Assingments' (I think, but you'll fnd it anyway, it's on the first page of Page Set Up). This shows a white background and black lines.
Then move to PaperSpace (in 2002 the layout you've created) and this will show a monochrome view of your drawing.
Hope this helps.
Fawkes
Try 'autocad object in mathcad'
Fawkes
