CABLES RATING
CABLES RATING
CABLES RATING
DEAR ALL
IF ANY ONE CAN TELL ME WHERE CAN I FIND THE TABLES FOR CABLES RATING CURRENT UNDDER LOW VOLTAGE(220/400 V)AND THE EFFECT OF TEMPERATURE TO CHOOSE THE SUITABLE SIZE OF CABLE TO CARRY RATED CURRENT (THANKS)
RE: CABLES RATING
If you're in the USA, or a jurisdiction that follows USA standards, look at the National Electric Code available from www.nfpa.org .
RE: CABLES RATING
High Ahmed
This cable information is freely available from suppliers and is also contained for generic cable types in the appendices of the relevant statutory instruments as applicable to your country of application.
For US applications, the NEC Code is the one to follow (as Ron says), here in the UK, the IEE Regulations BS7671
(a subset of IEC 60364) apply.
My concern is that either of the above standards would require the application of appropriate skill / knowledge and care to carry out designs, this applies regardless of whether you are sizing a single cable or designing a tower block.
Here in the UK, compliance with national statutory instruments such as "the electricity at work act" is achieved and demonstrated by compliance with BS 7671.  Should an incident / accident or dangerous ocurrence result from a dangerous non-compliance, the HSE can prosecute and incarcerate or impose heavy financial penalties.
No doubt a similiar situation is true in the US
refer www.hse.gov
If in doubt, speak to a suitable professional electrical engineer who understands the relevant regulations and can assist you.
RE: CABLES RATING
Ty this page, maybe it'll help:
http://www.elka.hr/main_en.htm
Here you have product catalogue, download power cables up to 1 KV and browse through it.
At the end, you have some information regarding temperature.
MissMe
