conversion of the A48C3S from AFNOR to ASTM
Please I can't convert the nuance of this Materiel (A48C3S). This nuance is in old designation AFNOR and i want to convert at ASTM code.
thanks...
thanks...
RE: conversion of the A48C3S from AFNOR to ASTM
http://metals.about.com
It helps me every time.
C = 0.25-0.35
Si = 1.00 max
Mn = 1.00 max
Cr = 13-15
I am not that familiar with this type of steel casting alloy, so hopefully someone more knowledgeable will respond with an equivalent ASTM standard.
http://www.westyorkssteel.com/Steel_Spec...
