H2SO4 Corrosion Stainless Steels
We were enquired on a new reactor to handle the following mix:
14.000 lt caju oil + 500 lt of H2SO4 (diluted 50%).
The oil goes first into the tank and then the acid is mixed.
The working temperature is 220ÂșC at 4 Bar.
Can anyone suggest a propper SS to use in the construction of the reactor? Considering the temperature is there a propper SS at all?
Thank you!
RE: H2SO4 Corrosion Stainless Steels
How much water is there?
What are the reaction products?
I presume that there is excess acid, how much?
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Hello, thank you.
The dat we received from the client is that the mix will be 14 000 lt of cashew nut oill + 500 lt of H2SO4 (diluted 50%). We don't know the exact percentage of water in the oil.
