150 Bar Gas Pipeline
Maybe you people can help a little.
There is a case here in Ireland where some farmers are protesting that a gas pipeline is coming too close to their house.
It's a 150bar pipeline carrying dirty gas direct from the gas field to the refinery.
It's designed to 345bar, it'll be buried at least 1.2m, steel with concrete protective coating, internal and external corrosion.
Can anybody offer any insight or comment?
RE: 150 Bar Gas Pipeline
Why is an onshore gas pipeline concrete coated by the way?
Steve Jones
http://www.pdo.co.om/pdo/
I don't know too much about the case or gas pipe lines generally to be honest.
http://risingtide.org.uk/node/29
would be a residents point of view site
and
http://www.shell.com/home/Framework?siteId=ie-en
is the company website
Steve Jones
Steve Jones
70m would sound alot better.
Considering the number of high pressure transmission lines that run through the UK, I don't think there's much concern- one ran through the car park at one the offices I worked in my first time in Aberdeen- big signs with energency telephone numbers next to the road. It wasn't odourised either.
And I don't think the gas in the 150bar Interconnector 1 or Interconnector 2 pipeline, which run onshore to the North of Dublin (Interconnector 1 since 1993 without mishap) is odourised either.
It looks to me like the standard "we're going to protest becasue it's the oil industry, it's Shell, it's globallisation .....".
http:
http://
http:/
Steve Jones
Steve Jones
