Command button to increment a cell by 0.1
how do I
increment Cell by .01
ie
start
 k2=k2+.01
end
RE: Command button to increment a cell by 0.1
If the cell position is fixed use the Range object:
Range("K2").Value = Range("K2").Value + 0.01
If you want to access the cell position in code, use the Cells object:
Cells(2, 11).Value = Cells(2, 11).Value + 0.01
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
if you just want click around on the sheet and add to where ever you are
Sub add_to_it()
ActiveCell.Value = ActiveCell.Value + 0.1
End Sub
place the following code (an event procedure) in the code pane for the worksheet where you want to increment
Private Sub Worksheet_BeforeDoubleClick(ByVal Target As Range, Cancel As Boolean)
With Target
.Value = .Value + 0.01
End With
Cancel = True
End Sub
double clicking any cell will increment it by 0.01
You can refine the event procedure by exiting quickly if the target cell is not one of interest.  For example suppose only cells A1:A10 should be incremented then use the following
If Intersect(Target, Range("A1:A10")) Is Nothing Then Exit Sub
With Target
End With
Cancel = True
End Sub
Just to add that you should check if the value is a number before adding, as you may get an exception if you try to add to a string.
    With Target
        If IsNumeric(.Value) then .Value = .Value + 0.01
    End With
    Cancel = True
End Sub
