Dimension Box
Dimension Box
Hello I just recently started using Solidworks 2005 and I am having trouble. Sometimes when I double click on a dimension that I just made instead of bringing up the simple box to change the measurement it brings up a read only dimensions box that doesn't allow me to change anything. Any ideas? Thanks
RE: Dimension Box
If you double-click a feature in your tree you are able to change the dimensions from there. The blue dimensions are feature-driven and the black dimensions are sketch-driven.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.1
RE: Dimension Box
RE: Dimension Box
RE: Dimension Box
RE: Dimension Box
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
RE: Dimension Box
RE: Dimension Box
If you placed the dimensions using the Insert > Model items method, you should be able to modify them.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
RE: Dimension Box
