S1 stress for Zick Analysis
When superimposing the external pressure stress in the longitudinal axis with the bending from the saddle reactions are you supposed to compare it to min(S,B) from UG-23 of ASME SC VIII-I or are you supposed to compare it to B/3 from UG-28? Thank you in advance.
RE: S1 stress for Zick Analysis
Allowable (-)S1 = the smaller of S or B
Thank you very much.
