load-bearing capacities of steel.
i am in tool & die and am starting to fabricate misc. things out of square tubing and other types of structural steel. i need a chart or book with load bearing capacities. i want to be sure i build things that can hold or lift the weight i build it to hold.
RE: load-bearing capacities of steel.
You could probably order the Ninth Ed. from their website - www.aisc.org (if i remember correctly)
