2:1 Elliptical Heads
Once again I like to say what a great forum this is, I have been doing a lot of my research on here. Well my firm made the jump to solidworks, so add 6 more seats to the total count. The past two days have been a blast.
I have started building templates for our major components. Basically all the shapes are the same with just different dimensions. This is working out great so far.
2:1 elliptical heads. I would like to setup a simple vertical vessel, and add the nozzles later for project specific. Kind of a go buy template
On to the question.
Should I table drive the heads with mathematical formulas, or should I use the old AutoCAD 1:1 trick and build it 1" long and scale it to the shell? I don't neccessaryily need a true repensetation, just something that's pretty close.
On to the question.
RE: 2:1 Elliptical Heads
Get away from the old AutoCAD and move up today's CAD systems
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
Garland E. Borowski, PE
