Servo Motor Humming
Servo Motor Humming
What could be the possible causes for a humming servo motor ?
I am new in the field and if you need more details please ask.
Thank you
Thank you
RE: Servo Motor Humming
Gunnar Englund
www.gke.org
AMPLIFIER DRIVE REDUCE PROPORTIONAL OR INTEGRAL GAIN THIS CAN BE A COMMON FAULT.MAKE ANOTE OF THE SETTINGS INCASE
ALSO THE ADJUSTMENT SHOULD BE DONE WITH A SCOPE BUT YOU CAN DO IT WITHOUT ONLY MAKE A VERY SMALL ADJUSTMENT.
gcastro;
Along with skogs question,
What size servo?
What is it driving?
What is controlling it?
