V5 specification tree - Not found
I am new for V5, during my practice session I lost the Specification tree. F3 also does not work. I was told the tree might gone into zoom condition and check the dot mark. But i could not trace it.
Can anyone suggest me how to reset the specifictaion tree.
Thanks in advance,
RE: V5 specification tree - Not found
If you have lost the tree in a zoom, here is the easiest way to get it back:
select View -> Commands List...  -> Swap view/tree (command) or enter "c:swap view/tree" in the power input field.  This will hightlight the tree, and you will then use the "fit all in" toolbar, or enter "c:fit all in" in the power input field.
If that doesn't work, then you have a different problem.
Check out CATBlog!
I'm sorry - just to clarify my last post - in case you've never used, or heard of it, the "power input field" looks like this:
You know - that little white space that nobody ever uses in V5.  I was classically trained in Autocad, and I just *love* typing things.  V4 was nice for that, and I'm a little disappointed that V5 doesn't offer more manual input.
I definitely use it whenever I get the chance, though.
Check out CATBlog!
Thank you,
I have resolved my problem with your instructions. Me too a V4 person presently working on V5. i also face difficulties in searching the icons.
write2shivk@yahoo.com.
Very nice...  Thank you.
I learned something today.  It's amazing how you can miss the simple things.
Check out CATBlog!
