No shaded with edges on assembly ?
I have a assembly that doesn't allow me to shade the assembly. So it displays in wireframe mode only, is anyone having the same problem in sw2005 ?
Printed Circuit Board Designer
Salt Lake City, Utah
Stangs rule!
RE: No shaded with edges on assembly ?
Just the one assy ... no others?
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
Stangs rule!
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
As arcticcatmatt suggests, when the problem assy is open, check whether the large assy mode has been activated.
Go to [b]Tools[b] & select or toggle Large assy mode on & off to see if that corrects the problem.
Also go to Tools & select Assembly statistics & post the results.
That worked ! Thank-you for your help .
Stangs rule!
