accuracy in solidwork
Hi all,
how do you increase the accuracy in solidworks?
Lee
Lee
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: accuracy in solidwork
SW does not use the same "tolerance" concept that some other programs use.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
I'm having problems exporting solidwork model into Pro/E ( surfaces didn't connected, surfaces weren't tangent to each other, edges of surfaces looked faceted not smooth, ....)
In Pro/E, users can increase the part's accuracy so that they get higher quality exported files (in iges, step,...etc), meaning the gaps between merging surfaces are smaller.
lee
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
1. export w_t format from SW
2. reimport it back to SW
3. export it again in STEP from SW
4. import STEP file into Pro/E
lee
You might try IGES, it tends to work better with Pro/E. Alsot try ACIS (*.sat). There are some export options that allow you to specify "high trim curve accuracy", as well.
On the Pro/E end, try changing from relative to absolute accuracy. Also, Pro/E does have some repair tools available.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Chris
FAQ559-1100
FAQ559-716
http://
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 3.1 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Are you exporting orthogonal parts, or spline based curves. Is it possible that Pro/E interprets splines differently from SolidWorks?
JHG
Christopher Zona - Senior CAD Designer
Litens Automotive Partnership
Concord, Ontario, Canada
