steam & vacuum pumps
Gents,
Have any of you had any experience on using saturated steam hoods to reduce moisture on pan filters?
I am very interested on what kind of effect could I expect on vacuum pump suction capacity.
I guess that it should increase capacity based on a condensation effect.
Seal water temperature would not be an issue since inlet temperature is always kept on target range with a cooling tower
Thanks in advance for your thoughts
