Using favorites when using the hole wizard
I just noticed that you can't use favorites when using the hole wizard. Thats not good. If you dimension a dowel hole with the regular dimension tool, you can use favorites (i.e. fits). But if you use the hole wizard (for when you have 12 holes and you want it to say 12X in front of it then your fit) you can't use favorites.
Hope someone understands what I mean. Where can I email solidworks a suggestion?
RE: Using favorites when using the hole wizard
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
To submit a suggestion to Solidworks go to the SW website and do a search for "Enhancement Request" You may need to log in with your serial number to get access
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.1
you are correct. I make 12 holes using hole wizard. Then I want to dimension them with a "favorite" for the fits and such but when you use the "hole callout" you are unable to use any favorites and have to do it by hand every time.
Another issue I found is that the numbers that solidworks uses for the hole and shaft fits are for regular steel. Almost all of our steel gets hardened. Therefore the tolerances would be slightly different. If the hole was made to MMC and the shaft was made to MMC, the hardended steel would split and break. It would be fine if the block with the hole in it wasn't hardened.
I am sorry if I am being confusing. I guess its sorta hard to describe.
For example - I make a .3125 hole and tell solidworks its a pressfit hole. I would like to use an FN2 fit for that (medium press fit) which is an H7 for the hole. I dimension the hole and tell solidworks its an H7 hole and it gives it a +.0006 -.0000 tolerance. The dowel standard is +.0002-.0000. With the soildworks standard, the dowel would slip right thru the hole and not be a press fit.
But, if make a shaft to go in the hole I made and dimension that, it is +.0014 +.0010 (it gives it a ++ tolerance) and that would create a good press fit for that shaft in the hole if it was regular (non hardened steel).
I don't really like them numbers from the machinery handbook. With the above example.. there is the possibility of creating a press fit that has .0014 of interference! And that is just a medium press fit (FN2). We have decided not to use that mach. handbook or solidworks numbers. Too bad too because that could be a really awesome feature of solidworks.
