pattern feature
pattern feature
pattern feature
Anyway to do a window pick on instances that you would like to skip in a pattern?
RE: pattern feature
If it is a sketch pattern, edit the pattern, select the instance in the "instances" in lower panel, delete. It will move to the lower right panel "instances deleted".
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
RE: pattern feature
You can do the same skipping in patterning features.
