Corosion Resistant Coatings
I have an application in which I will be gluing a friction material to mild steel which needs to have a corosion resistant coating. Currently, the coating is zinc phosphate but I can switch to zinc di-chromate if need be. The adhesive is phenolic based and is baked at 400 degrees F.
My question is would one of these plating techniques bond more tightly to the steel and, thus, form a better substrate for the adhesive?
RE: Corosion Resistant Coatings
http://www.welding-advisers.com/
