helix along a path?
helix along a path?
helix along a path?
hi
I've been looking around the forum for a helix lisp that will run along a path. Can anyone point me in the right direction?
thanks
sundemon
RE: helix along a path?
Hi Sundemon, what do you want to do?
It is easy to extrude any profile on a 2d path , but only a circle on a 3d path.
www.cadtutorforum.net
hi hyposmurf;
sorry for the delay in getting back to you, I had a day off!
I was trying to draw a 3D flexible accordian-type hose running along a curved path. I thought that if I could run a helix along the path, that would be a useful visual element in the drawing. I have a few helix lisps, but the only can be created in a straight line. I searched around various lisp libraries, but I didn't see anything that would follow a path.
As a workaround, I ended up creating a helix with a single revoltion, making that a block, and placing an aligned arrangement along the curved path through the "measure" command.
Still, I would be interested to know a good method to represent a bending flexible hose.
BTW, I have extruded shapes other than a circle along the helix, but the alignment of the extruded shape can be unpredicatble. Also, you end up with a very heavy drawing in terms of file size.
Thanks for answering,
sundemon
A helix for every occasion.
http://www.cadpanel.com/downloads/spiral.zip
and...
http://new.cadalyst.com/code/browseyear.cfm?fullyear=2000
"we should only try to get even with those that are helping us."
