Poisson's ratio at elevated temperatures
In metals, E and Fy decrease as temperature increases. Is Poisson's ratio affected by elevated temperatures (100 deg F to 1000 deg F)?
RE: Poisson's ratio at elevated temperatures
My recollection is that the general trend is a lowering of Poisson's as temperature increases (but not with 100% certainty).
I think I may have a reference about more specifics. I'll try to dig it out.
Brad
INCO 718: 0.294 @ 70F; 0.306 @ 1400F
INCO 625: 0.308 @ 70F; 0.329 @ 1400F
A286: 0.280 @ -320F; 0.300 @ 70F; 0.360 @ 1600F
Does anyone have any data for Aluminum and Al-Li alloys?
At 20 deg C,
E=70.3*10^9 (Pa)
G=26.1*10^9 (Pa)
Tempco for E is -480 ppm/degC
Tempco for G is -520 ppm/degC
For a homogeneous isotropic solid,
Poissons Ratio =(E/2G)-1
By plotting Poisson's Ratio against temperature the tempco for Poisson's Ratio for Aluminium at 20C turns out to be +55.6 ppm/degC
For Inconel 600, Poisson's ratio first drops, and later rises again with temperature..
I took my data from the publications at www.specialmetals.com
