How to enter text in TextBox?
Hallo, I'm want to enter a text in text property of TextBox. I read help exampels and using the following part of cod
  Sub Eltablo()
    Dim Trafopost, Izvod As String
    Dim StalbNomer, TabloNomer As String
    Dim tipTablo As String
    Dim EPN As String
    Dim Electromer, Tok As String
    Dim Chasovnik, ChasovnikNomer As String
    Dim Tarifi, Fasa, TT, NT As String
    Trafopost = "TP 1"
    Izvod = "A"
    StalbNomer = "1"
    TabloNomer = "1"
    tipTablo = "TEMO 1M"
    txtTrafopost.Text = Trafopost
    txtIzvod.Text = Izvod
    txtTablo.Text = tipTablo
    txtStalb.Text = StalbNomer
    txtTablo.Text = TabloNomer
  End Sub
but it does not work.
Pleas tell me why?
RE: How to enter text in TextBox?
There is a few points:
CODE
will Dim Trafopost as a Variant and Izvod as a String.
CODE
is overwriting the value in txtTablo from tipTablo to TabloNomer
Is this Word VBA? The code works fine for me - where is the Sub and how are you calling it?
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
Thank you for answer. This is AutoCad VBA and I found my mistace. This realy works fine.
