Torquing 300 Series Stainless Steel Bolts
The standard torque equation is T=KFD where T = torque, K is the "nut factor," determined experimentally, F is the force (LBS, N) and D = the nominal bolt diameter.
Does anyone have any data/experience with the value of K for 300 series bolt material, e.g., A193-B8? As received values (dry) are in the neighborhood of 0.3. But what is the value when you add a lubricant?
RE: Torquing 300 Series Stainless Steel Bolts
Somewhere in the neighborhood of 0.17 to 0.20 would be considered a "generally accepted" value.
However, as you noted, this should be determined experimentaly for your particular application and lubricant.
Of course, if your application is important you should consider something better than torque control for controlling fastener preload.
Correct MintJulep, 0.20 although Mark's lists 0.15.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
If the friction is doing you a favour, use 0.15. If it is working against you, use 0.3. That's steel on steel, not rusted, etc.
Cheers
Greg Locock
MintJulep, Cockroach, GregLolock ...Thanks for info. Basically what I thought.
