Linking vault assy's to parts in the vault
The problem I am having is that when our company bulk checked in top assy's some sub-assy, and or part files remained linked to folders outside the PDM works vault, is there an easy way to "re-link" the top assy to the "new" re-named sub-assy's that were checked into the vault?
e-
e-
RE: Linking vault assy's to parts in the vault
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.1
I suppose I should clarify something: Do the files outside the vault have the same names as the files inside the vault? If that's the case, jksolid is correct; you will need to reference the files in your working directory (instead of the network) prior to check-in. If the files have different names, you will need to reassemble the assembly with the correct file names.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
