Problem with SR489 Multilin
Hi everybody, I'm getting a problem with one SR489 Multilin, one of its analog output sudently change signal level, This refers to MVAR, and is calibrated to:
4mA=-3.37MVAR to 20mA=3.37MVAR. At normal power factor it got 0.9MVAR but sudently it increased to maximum setting (3.37MVAR). I did changed the input analog module on PLC in order to eliminate this posibility. I see the problem is with SR489 relay. What can I do, in order to fix it? Thanks for your help.
Ealberto
Ealberto
RE: Problem with SR489 Multilin
Don't forget that the MVAR can be positive or negative.
4mA=-3.37MVAR
There's a '-' symbol there. I didn't spot it either at first read. Agree with the rest. I'll enquire whether we've had anything similar with our Multilins.
If we learn from our mistakes,
I'm getting a great education!
