Steam Conversion
Steam Conversion
Guys,
I'm new into the field, so this is probably an easy one for you guys. Does anyone one know the conversion of sq. ft. of steam to BTU's. Also in addition I have a Burnham V-909a steam boiler thats getting piped into a shell & tube heat exchanger, converting it into 80 degree condensing water for a heat pump application. Does anyone know a good link for a typ. piping arrangement for the boiler? Any help would be appreciated. Thanks
RE: Steam Conversion
I hope this helps.
