Dimensions/osnap
Dimensions/osnap
Dimensions/osnap
I'm having two problems:  (Autocad 14)
1.) When i'm dimensioning something, it is already exploded.  In my former job i worked with Autocad 2000 and i know that it has a toggle to be exploded or not.  I just can't find it in autocad 14.  Does anyone out there know where i can find?
2.)  my colleague in th enext office, her OSNAP is not showing up, on her screen.  She has it turned on, and her OSNAP settings are checked on the ones she wants to  use.  Also, even when she right click and picks the Osnap from the menu it still doesn't show up.  Any suggestions?
Thank you for your time and help
Juice
RE: Dimensions/osnap
For item #1, is your DIMASO set to on?
When you talk about the osnap not showing up check your settings in preferences and make sure 1 that the color of the snap apature is set to a collor u can see with the bacground your using and make sure that it is a size you can see as well
also check the other settings there too
if everyone helps everybody the world will be a better place
