Question on AS/NZS1170.2002 (wind code)
re Table 5.3(C), Roof External Pressure Coeff'ts, specifically '(R) for hip roofs';
The first column notes that for (R) the table is applicable for all roof slopes. How then do you select the correct coeff't? There are values for 10 deg etc. but not for < 10 deg.
Do we use the 10 deg values where (R) slope is < 10?
RE: Question on AS/NZS1170.2002 (wind code)
I agree that there doesn't appear to be any other interpretation possible, but it does seem suprising to me that the coeff't for the side and downwind roof planes is the same.
