Thread on curved face.
Is it possible to create thread using helix and sweep-cut on countoured surface??
I want to add thread feature on "eye drop" shape face.
I originally used rev-cut, however, my boss wants me to show "helix" part of thread.
I wasn't sure if it is even possible..
RE: Thread on curved face.
You could create your helix and then sweep a cut for your threads along the helix.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
You can make several helixes, paths, etc... then use a Composite curve to make it into one continuous path. Then you can make your profile and sweep it along the composite curve.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
Thanks, SBaugh.
I will try that!
It gets thinner on both ends and it is fat in the middle.
The base shape is kind of like when you revolve the arc.
