Bushing (bearing) Load Calculation
I have a handle which is a rod attached to a pivot bracket. I want to determine what I need to know to select a sleeve bushing to put in my pivot bracket. I know my maximum load that I will pull on the handle with. The bushing would need to withstand that load. If I do a force balance and apply half of the load to one of two bushings and divide that load by my projected bushing area (diameter x length), is that stress the stress I need to use to select a bushing, or is there something more complicated going on?
J
J
RE: Bushing (bearing) Load Calculation
Jeff
J
