Rename Parts in assembly
How to rename the parts used in an assembly file in Solid edge 15.?
RE: Rename Parts in assembly
Patrick
In the mean time, I'm creating parts on the fly by opening the part in the existing assembly into part modeler, saving a "copy" to a new name, returning to the assembly, and using "Replace". This leaves the part on the central library untouched, allows you to edit a new part any way you want to, not having to manage where-used lists, and dealing with crapped draft-files and other assemblies, all to use a part that probably isn't under revision control yet anyway.
Let us know how it goes?
C. Fee
