Neu file?
Neu file?
Neu file?
Anyone ever hear of a .neu file extension? From what I could find it is some kind of ProE file but SW does not seem to recognize it. Is some kind of converter needed?
RE: Neu file?
From what I found it was called out as a Mensi 3D Laser Scanner file. For a good reference on file extensions I use www.cknow.com
Don't worry about people stealing your ideas. If your ideas are any good, you'll have to ram them down people's throats.
--Howard Aiken, IBM engineer
RE: Neu file?
Yes a neu file is a ProE file, I don't think you will be able to import in SW with it.. there may be a 3rd party app to allow this.
It's more of a between different releases of ProE thing
and I believe it doesn't retain the model tree, comes in as a import feature
RE: Neu file?
I second that Scorch a *.NEU files are Mensi 3D Laser Scanner File type.
http://filext.com/alphalist.php?extstart=%5EN
http://www.mensi.com/Website2002/index2.html
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 3.1 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
RE: Neu file?
must be both... go to your open and export options in ProE and you will see it right there, called a neutral file ext. .neu
heres the header;
#UGC:2 NEUTRAL 972 440 0 0 0 15 2300 2001150 00000000 \
#- VERS 0 0
and it does come in as a import feature in ProE, like Iges or Step... so no tree
RE: Neu file?
Neutral files with .neu extension are also used by Femap for translating models between fea solvers.
Tom Stanley
RE: Neu file?
One thing that will really let you know that it is a ProE file is if it has a numeric on the end;
somefile.neu.5 or neu.4 etc.. I doubt the others throw on that pesky number at the end
