Frost Protection for Bridge Abutment
Hi All,
Here is the situation. A client has asked us to look into roadway widening for a development and the widened section of roadway goes under a bridge. Additionally they need a sidewalk to be added. Unfortunately, as we widen the road way we start to encroach on the bridge abutment. To solve part of that problem we've looked into retaining walls to hold back the soil on the toe of the abutment. However, we're still faced with a situation where on one of the abutments we no longer have adequate frost protection. Incidentally, it is a stub abutment on spread footings. I'm still trying to wrap my head around the project, used to be someone elses job then got plopped onto my desk. What I'm looking for is any resources or suggesting in addressing the frost protection issue. I've read about styrofoam insulation but I'm not convinced this is a good solution. Any suggestions would be greatly appreciated. Also, I've checked out several cold weather state's bridge manual but I can't find any alternatives to frost protection other than making the foundation deep.
Andy
Andy
RE: Frost Protection for Bridge Abutment
Can you raise the sidewalk grade up to maintain the frost protection over the abutment footing? You may need to provide a grade separation (berm, retaining wall?) between the underpass road and the sidewalk.
If the bridge has a spillthrough abutment, you could probably run the sidewalk up on the spillthrough slope a bit.
Hope this helps,
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
