Cracking of HNBR diaphragms
We have a case of a thin rubber (HNBR ~ 1-2mm) diaphragm in a high pressure CO2 valve failing. It had cracked completely round the flange plus part thickness crack around central support plus a few smaller concentric cracks. It is not ozone cracking. We suspect valve may get cold under some operational conditions (CO2 expansion)and that diaphragm could have cracked when it operated. Any experience? Anyone know how cold HNBR would have to get? Thanks
RE: Cracking of HNBR diaphragms
