Current Limiting Fuse Application Information
I'm looking for information on applying current limiting fuses, particularly for arc flash hazards. The IEEE Red Book only contains a very brief discussion of CLFs. Does anyone have any links to resources?
Thank You
wbd
Thank You
wbd
RE: Current Limiting Fuse Application Information
When considering CLFs for arc-flash protection, the biggest issue is making sure there is enough short-circuit current available to get the fuse into its current-limiting range. If the fuse takes longer than 1/2 cycle to operate, it isn't current-limiting.
