rotating frame check box
I am working my way trough the floworks 2004 tutorial but i can not find the rotating frame check box. It’s needed for a pump calculation.
Any one knows what I’m doing wrong or where is it located?
Greetings Q
Greetings Q
RE: rotating frame check box
If you bought FW with a Standard lic and you didn't know that, probably your reseller can help you shift the license.
If you use at home a cracked version of FW, ensure that the lic file doesn't contain both the lines for feature Floworks Pro and Floworks Std: they are not additive, so simply cancel from the lic file the "Floworks Standard" block. Using unofficially licensed programs is on your own to decide, in most countries it's illegal, so I give you this trick "as is"...
