hot work temperature
I would like to know what is the hot work temperature for bending of PNo=1 to PNo=7 materials .
RE: hot work temperature
The hot working temperature of metals is specific to the material classification (type and alloy content), and can vary from 1700 deg F up to 1900 deg F. For example, the P-No ranges you are interested in contain various alloys like carbon steel, low alloy steel, martensitic stainless steel and ferritic stainless steel.
Your best bet is to pick one alloy in each material classification and search the internet for technical information. The key word(s) I would recommend to use is formability or hot forming.
ASME B31.1 129.3.1 defines hot bending aa being done above the lower critical temperature - 100 F. Cold bending is performed at a temperature below the lower critical temperature-100 F. The lower critical temperatures for P-1 thru P-5B are provided in Table 129.3.2.
