V4 Layer problem
V4 Layer problem
Usually in the "list of LAyers" there are layers 0-254 listed. When I open our seed model only layers 0 and 4 are listed in the list of layers. But i can open the same model on a different scope and there fine. Dont confuse this with the layer filter. This is in the list of layers. Thanks Atcoast
RE: V4 Layer problem
I'm not sure I know what you mean. There is a list of layers under several of the layer sub-functions. Please be specific, as this could pertain to a filter, or it could be something else, depending on how you are seeing this "list of layers."
Check out CATBlog!
Glad you got it worked out.
Check out CATBlog!
