Solid Problem
Solid Problem
Solid Problem
In v4.2 drafting mode i am updating a large view and I get an error "solid problem" what causes this? how can you find the problem solid in a large overlay? Thanks Atcoast
RE: Solid Problem
After the error message type /help it ay give you more info about where the problem is.
I said 'may', didn't I    ;)
Eric N.
RE: Solid Problem
No, you said "it ay," but that's probably just as good...
Check out CATBlog!
RE: Solid Problem
Are you sure that your CATIA settings for usrenv.dcls are OK for what are you doing?
If I remember well, I had a similar problem in the past. The problem was that my settings for CATIA were to "small".
There is a very good article on IBM site called "MEMORY MANAGEMENT IN AUXVIEW2, METHODOLOGY"
May be this article can help you.
Fernando
RE: Solid Problem
is your Model clean.  Try typing in /cln to check for errors.  Caterogry 1 and 2 errors will stop drawings from updating in Auxview 2.
Darren
RE: Solid Problem
Thanks everyone the problem is solved. Seems there were a few solids that needed to be updated in detail wsp.
Thanks again.
