Piezoelectric harmonic analysis
Drej and cloche thank you very much for your help.
Let me in more detail explain what I want to do with piezoelectric harmonic analysis.
I have 10 piezoelectric discs stack, each disc has a hole at the center and these discs inserted on vertical stainless steel cylindric bar above each other. Totally I specified 12 material properties 10 for piezoelectric elements and 2 for stainless steel cylindric bar and bolt.
If we apply voltage between top and bottom electrodes on piezoelectric disc this piezoelectric material will shrink with some magnitude of displacement. So, when each piezoelectric disc of stack, fastened from both sides, shrinks, the stack will vibrate (Actuator working principle). If I join this model with the spring, then while shrinking by each piezoelement, the stack itself starts to vibrate, because piezoelements pretty well fastened from both sides.
Doing harmonic analysis I want to determine vibration amplitude (stainless steel bar tip UY-displacement) over frequency.
I selected as an element type PLANE223(Structural+ Electrical)which takes into account piezoelectric phenomenon, and also COMBIN14 which takes into account spring phenomenon.
DOF for PLANE223 is UX,UY,VOLT. DOF for COMBIN14 is UX,UY,UZ. For one end of the spring, for the displacement, I applied ALL DOF and specified value of zero. On the other end of the spring (connected with the assembly of piezoelement stack)I selected UX and UZ in order to constrain the node in these directions, and also I unselected ALL DOF.
As a load, I apply voltage at the interface of each piezoelement, and interface of piezoelement and stainless steel.
When I ran this analysis I thought I could get the plot of amplitude over frequency, and could determine the vertical displacement (amplitude) of the whole model. But in Time History Variables Viewer when I select: Add->Nodal Solution->DOF Solution->Y component of displacement->I select node on the tip of my model, it does not show any value for amplitude (Minimun, Maximum).
Does all I explained make sense to you?
May be this time, after I explained in more detail my problem, you will be able to help me.
Thanks a lot guys
Thanks a lot guys
RE: Piezoelectric harmonic analysis
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
When I run harmonic analysis for Piezoelectric material I get this error message from TimeHistPostpro:
can't read "p26WinArr(LAYERP26)": no such element in array
while executing
"{::namespace inscope ::euidl::results::timeHist addDataDlg_CB1} 0"
("after" script)
Does anybody know what it is, and what shall I do?
2/ select the elements that you want to change the materials properties for (ESEL,...)
3/ Issue the following: EMODIF,ALL,MAT,2 (modify all elements to have material 2 properties)
