USING 3 OR 4 POINT FIT IN UG NX 3
I am trying to do a transform / 4 point fit on 2 different blocks that are on different planes and angles.( the blocks, or the point pattern is the same for both blocks). I need to align, or fit 2 of the surfaces together. I can do it in SDRC Ideas, but can't figure it out in UG. Any ideas is greatly appreciated.
RE: USING 3 OR 4 POINT FIT IN UG NX 3
and then Sequentially select the points to transform.
all the best
Nagesh
