PC Serial Port Stepper Motor Interface Card substitute
Aloha,
Ocean Controls offer the PC Serial Port Stepper Motor Interface Card which would suit my needs perfectly, but since they are located in a non-US country it will be hard for me to obtain a purchase order.
Do any of you know of a US made subsitute?
Here is the link:
http://www.oceancontrols.com.au/motor_controller/stepper_motor_controllers.htm
I'm wanting to purchase a device that is sold in the US that has the same functinality/similar functionality as the this card. I've done google searches, but I only recieve packages that recieve serial input and output the leads for the motor.
This card takes input from the RS232 serial port of a PC and converts the ascii commands into step and direction signals. These signals can then be fed to stepper drivers.
It is important for me to have the controller (step & direction) be separate from the drivers because these two devices will be located on two oposite sides of a copper wall and the least amount of leads penetrating the wall is prefered. So there would only be 4 or 5 leads penetrating the wall if I were to use this card.
Mahalo
