Average pressure in gas pipe
5
Hi Firends,
      This is my first post. Please tell me if made any mistake in the explanation of my problem.
      There is a high pressure gas pipe of uniform CSA - fixed installation - carrying nitrogen from a cylinder to nozzle. I need to calculate the average pressure in a certain section AB of the pipe. The parameters that I have in hand are:
* The pressure at both the ends of section AB
* Temperature of the gas
* Design flow rate through the section AB
       I assume that the average pressure is simply the average of the pressure at the two ends. I am a beginner in this area. So I am not sure if my assumption is correct. When I googled, I saw how to calculate the average pressure inside a container, but I think that would not suit my case.
Your advice on this is greatly needed.
TIA,
Caddy
RE: Average pressure in gas pipe
I would say that your approach for calculating average pressure over length AB is reasonable for fluid flow. For most fluid mechanics applications, flow of a fluid (gas or liquid) is described by a very simplified version of Bernoulli's equation where
delta P/g + 1/2 velocity ^2/g + height = constant
Thus, to have flow thru a horizontal pipe (height = 0) of constant cross-sectional area, velocity of the fluid is related to pressure drop and density of the fluid.
Since you have the delta P, the average pressure over the length of section AB would be (Pa + Pb)/2
Dear metengr,
       I was not quite sure if the average of the terminal pressures will give the average pressure in the pipe. Since the system involves high pressure, I thought, the change in pressure over the length of the pipe might be non-linear and hence some complicated formula might be involved in the calculation. Thank you for the reply.
Caddy
As the pressure of the gas decreases due to flowing losses, the density will decreases and the velocity increases and the head loss per foot will increase (and there is another effect here from temperature).  If you plotted the pressure loss down the pipe, it would increase the farther you get from the inlet which I believe is your concern.
IF the losses are however reasonably small you can neglect the effect I've just described and use the approach you asked about.
It seems to me that any application that required the "average pressure" is probably also approximate enough that it wouldn't matter how you actually averaged it.
We're assuming you don't have a shock wave in the section in question, in which case, you'd have big  variations in pressure.
Thank you TD2K and JStephen for your ideas.
Shock waves are not a concern because the calculations are for the system in steady-state. Moreover the system does not have an external source to feed it other than its own nitrogen cylinders.
As TD2K said, I was concerned how the plot of pressure loss versus the distance from the inlet would look like. If the effect of temperature is neglected, I think the plot will be a straight line(I am not sure, though). Then one could use the average of the end pressures as the average pressure of the section. Otherwise the formula must be modified based on the shape of the curve.
The length of the pipe section could vary from just a few feet upto about 200 feet. I needed the average pressure to calculate the average density of the gas in that section. Since the pressure loss for longer pipe sections are not negligible, I thought it might be appropriate to clarify my approach to find the average pressure.
When I work on problems that require density, I calculate the density at the head of the pipe and then at the tail.  If they are "close enough" to each other I use the average, if not I find a different equation.  "Close enough" depends on what you're trying to do.  Some problems give you good enough answers if the values are the same in the second decimal place, others matter if there is a difference in the fifth decimal place.  It all depends on the quality of your data (e.g., if you have a +/-5 psi gauge then taking density to 7 decimal places is silly), and the importance of precision in your answer (sometimes you want to know whether a volume flow rate is thousands of standard cubic feet per day or millions of standard cubic feet per day and other times it matters if you have 159 or 175 MCF/d).
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The harder I work, the luckier I seem
The correct equation to calculate the average pressure in a gas pipeline flowing under steady state conditions is:
Pavg=(2/3)*(P13-P23)/(P12-P22)
This equation is quite common in the natural gas industry, especially in the natural gas transmission field.
About 25 years ago, I looked up the original paper that introduced the Weymouth equation. I found that Prof Weymouth also derived the average pressure equation in the same paper.  I guess you can call this the Weymouth Aerage Pressure equation .  (If anyone is interested, the reference is: Problems in Natural-Gas Engineering: Trans. Am. Soc. Mech. Eng., vol. 34, 1912, pp 185-206.)
RGasEng;
Interesting information. Here is another equation that was referenced by AGA and generally accepted for determination of average pressure in a pipe, which accounts for non-linearity of pressure drop over distance;
Pavg = 2/3[P1+P2 - (P1*P2)/(P1+P2)]
zdas04 (Mechanical)states"It all depends on the quality of your data .....'I concur
Are the both end pressures measured?
OR is one pressure measured and the other calculated--If so, what formulas/assumtions are used for the calculation?
Are the temperature measured or calculated--If calculated what formulas, etc?
metengr:
I have seen that equation before.  Although I have not done the algebra in a long time, I believe that they can be shown to be algebraically equal.
They don't seem to be algebraically equal.
a3-b3 = (a-b)(a2+ab+b2)
So, (P13-P23)/(P12-P22) = (P1-P2)(P12+P1P2+P22)/(P1-P2)(P1+P2) = (P12+P1P2+P22)/(P1+P2)
So the algebraic sign of P1P2 should be + rather than -
I wish I had the paper with me.
quark:
If you multiply and divide the  right-hand side of the equation metengr wrote by (P1-P2) then you will come to the equation RGasEng has written.
Thank you everybody for the posts. Since the result of average pressure calculations are used for further calculation of other parameters of the system, I wanted it as precise as possible and at the same time trying to not go beyond what is needed. Since the latest equation cares for non-linearity also which is exactly what I was looking for and also is an accepted standard practice in the industry I am very happy.
I am sorry, it is wrong on my part. I thought the denomnator was for entire RHS expression.
Metengr's formula for the average has apparently been evaluated at 4/3 the arithmetic average less 1/3 the harmonic average between P1 and P2, as follows:
4/3 (P1+P2)/2 - 1/3 [2P1P2/(P1+P2)] =
2/3 (P1+P2) - 2/3 P1P2/(P1+P2) =
2/3 [P1+P2 - P1P2/(P1+P2)]
Can you be a bit descriptive? I am poor in statistics. Why 4/3rd of A.M and 1/3rd of H.M? what is the idea behind it?
Thanks in advance.
To quark,
I got the results I mentioned by playing around with metengr's formula, having noticed the arithmetic mean (AM) and the harmonic mean (HM) of P1 and P2 are both involved.
The average pressure I found = 4/3(AM)-1/3(HM) may be (I'm hypothesizing) the result of applying numerical methods such as the trapezium rule or Simpson's rule to treat either experimental results or a friction drop formula and its curve.
Attached is the derivation of the average pressure equation per Uhl, A. E., et al., Steady Flow in Gas Pipelines,  Technical Report No. 10,  Institute of Gas Technology, Chicago, 1965, pages 85 and 86.
For the operating ranges usually encountered in transmission practice;   i. e., pressures below 1000 psia and temperatures of 60° F or higher,  the variation of z with P is nearly linear, so that the compressibility factor may be represented by a function of the form
Z=1/(1+aP)
where a is a Constant dependent on T.  The mean pressure (Pm) which must be used can be determined as follows:
(1/Zavg)∫P1P2  PdP  =  ∫P1P2  (P/Z)dP
or
(1+aPm) ∫P1P2  PdP  =  ∫P1P2  P (1+aP) dP
Upon integration
(1+aPm)(P1 2 - P2 2)/2 = (P1 2 - P2 2)/2  +  a(P1 3 - P2 3)/3
or
Pm  =  2/3(P1 2 - P2 2)/( P1 3 - P2 3)
If full integration of the general energy balance is desired, however, for the sake of extreme accuracy or where a computer program is involved,  the variation of P and T and the consequent variation of z along the line can be accounted for by graphical or numerical techniques.  Graphical integration could be effected by plotting   P/ZT against P,  and subsequently determining the area under the curve between the initial and terminal values of P.  An additional possibility would involve the use of an analytical or virial equation of state.
Correction
Last equation should be:
Pm  =  2/3(P1 3 - P2 3)/( P1 2 - P2 2)
(1/Zavg)?P1P2  PdP  =  ?P1P2  (P/Z)dP
Isn't the mean pressure  the integaral of Pdx (limits  x1 and x2)  divided by x2-x1    where x is the length   ?
sailoday28 (Mechanical)
I don’t know why you would introduce length in calculating the average pressure.  I don’t mean to be sarcastic, BUT() if you were calculating the arithmetic average, would it be (P1 + P2)/L  ?  I don’t think so.  Uhl is taking a weighted average of the flowing pipe pressure.  He introduced Pm via the simplified compressibility equation.  (I think Prof Weymouth did it the same way.)  Uhl then used the simplified compressibility equation with both Pm and PdP, integrated both sides and solved for Pm.
RGasEng (Mechanical)
If the pressure distribution is integrated over the length,
the resulting units are pressure*length units.  If one divides by a length the resulting units are in terms of pressure. ---The mean pressure--
You are indeed correct…..  I did my last calculus more than 30 years ago, so I may not be of much help to you.  I think to do what you are suggesting you need to specify P as a function of x before integrating.  You could probably use the flow equation as your pressure distribution function but one purpose of evaluating the average pressure is to plug it into the flow equation to correct for elevation.  I don’t know if your method would make this any easier.
RGasEng (Mechanical)Please refer to my prior post of June 25.  If those questions are answered then the pressure distribution as a function of pipe length may be obtained and if necessary, numerically integrated.
I have seen some of your posts on heat transfer and I have learned a great deal from them.  I also saw your prior post in this thread and paid it little attention to it because it did not contribute to the original subject.  I always try to help when I can but allow me to suggest respectfully that if you require answers to your questions or if you wish to pursue tangential issues you should start new threads.
RGasEng (Mechanical)The originator of the post stated"
 I assume that the average pressure is simply the average of the pressure at the two ends. I am a beginner in this area. So I am not sure if my assumption is correct."
I am under the impression that you now agree that the avg or mean pressure involves integration of pressure over length.  Further to have the pressure distribution,one then can use the formulas and assumptions used in obtaining end pressures.  Where are the tangential issues?
Respectfully
soday28
every know the formula PV=nRT.
at the first stage, it is right the average of the two ends.
But, that can change if there is:
- temperature variation
- Speed variation
- Pipes dimension variation (bends or ventury parts)
- modification of the nitrogen.
the is no statistics on that. We can have an exact calcul.
Can someone give me a simple lesson on placing equations in a response?
sailoday28,
There really is no way to insert equations per se.  The equations that you see are formatted text.  Eng-Tips uses the TGML compiler to format text.  If you look at the bottom of the reply box, you'll see a check box that says Process TGML.  Leave the check box checked but click on Process TGML.  You'll get a menu of TGML formats.  Formatting text is similar to writing computer code; just follow the rules and it gets easier with practice.  In most cases you can copy and paste the format examples and insert your text. As an example, I formatted the Colebrook equation below to show what it looks like before and after it is processed.  Note, in the before posting example, I substituted | for [ for illustrative purposes so that the TGML compiler would not process the formatting code.
Colebrook Equation before posting
1/|√]f= -2Log{(k|sub]e[/sub]/3.7D)+(2.51/N|sub]Re[/sub])(1/|√]f)}
Colebrook Equation after posting (replacing | with [ )
1/√f= -2Log{(ke/3.7D)+(2.51/NRe)(1/√f)}
Z=1/(1+aP)   Pv=RT/(1+aP)  v=RT/p/(1+aP)
1/v= P(1+aP)/RT
For isothermal process dP/v= P(1+aP)/RT dP     (****)
integral of dP/v from P1  to P=
1/(RT)[  P^2/2+aP^3/3 ]       (%%%%%)
Mean pressure
u velocity, x distance  p pressure f friction factor
v specif volume   D diameter    G mass flux  flow/unit area
subscirpt 1 conditions at pipe inlet
Dynamic eq. of motion
udu/dx + v dp/dx +fu^2/(2D)=0     (1)
conserv. of mass   u=Gv            (2)
Divide (1) by U^2 and substitute (2) into (1)
du/u  + 1/v(G^2) dP  +fdx /(2D) =0  (3)
 after multiplying by dx
du/u  from (2)=  dv/v
and (3) upon integration with f a constant becomes with substitution of  (%%%%%)  becomes
ln (v/v1)+1/(RTG^2 [P^2/2-P1^2/2+aP^3/3-aP1^3/3
+ f(x-x1)/2/D=0   or
-ln[p(1+aP)]-ln[p1(p11+aP1)]
+1/(RTG^2 [P^2/2-P1^2/2+aP^3/3-aP1^3/3+ f(x-x1)/2/D=0
The above is difficult to solve for P vs x.
However pick  P substitute and get x
Use numberical integ and  mean pressure may be obtained.
Hopefully others will check for algebraic mistakes in above formulae.
sailoday28
I'm a little too rusty to check for algebraic mistakes.  But one question: How do you deal with a ?
Note:In my formulas, I believe my algebra is correct, however, I have been careless with some parenthesis.   Also, the analysis is ISOTHERMAL.
To deal with a, there are charts of Z vs. reduced pressure (P/Pcritical) with reduced temp T/Tcritical as a varying parameter.
For 0<Reduced pressure< from 0 to about 0.8
along a constant reduce pressure line, the curves seem to be fairly straigt with a negative slope,  ie "a" is minus
Reference, for example Gouq-Jen Su, Ind. Eng. Chem., 38, 802 (1946)
This refernce inclues Nitrogen Methane, Ethane, Ethylene Propane, n-Butane, Isopentane, n-Heptane, CO2, H20  AND
Reduced isotherms of 1, 1.1, 1.2, 1.5 and 2.
Sailoday28:
      Sorry for the late reply to your post on the 25th. I was trying to familiarise myself with the equations and calculations related to pressure. I think it might take me ages to learn them all.
       Pressure at the inlet and density of the gas at the inlet are known. The flow rate of the gas is assumed to be constant and the value of flow rate is also available. Temperature is also assumed to be constant(Room temperature). I used the Darcy-Weisbach equation to calculate the exit pressure of the pipe.
      With the above data in hand, I needed the average pressure in order to calculate the average density of the gas in the pipe section(Average density is needed in the Darcy-Weisbach equation). Since average pressure is dependent on the end pressures, one of which is already known, the Darcy-Weisbach equation will contain only one unknown(the other end pressure), and can be solved for that unknown. This was my theory.
      But I did not realise that the compressibility of gas will make things so complicated. I need to mention that the nitrogen cylinders are custom-made high pressure nitrogen cylinders(usually 3000 psi, but sometimes upto to 4500 psi). I think even the sophisticated equtions of state are not suitable for this kind of situation(Please correct me if I am wrong). I am reading through books to see if there is some way out. If anyone could help
DrCaddy (Mechanical) Room temp of the nitrogen  gives it a relatively high reduced temperature, since Tcritical is about  227 Rankine.  The reduced pressure with pcritical approx 33.5 atmospheres is a possible concern.
I suggest looking into equations of state (eos)which are valid in the approximate range of temperatures and pressures of your interest.
Then the flow equations will have to be numerically solved--if the eos is to cubersome to handle with regard to integration, etc.
DrCaddy,
What will your actual temperature range be?
The IR Compressed Air and Gas Data 2nd Ed. 5th printing
pg 34-36 illustrates Z vs P for N2.  In the temp/press ranges that are specified, it appears that a linear curve fit is applicable with "a" being positive.
sailoday28 (Mechanical):
See thread687-127478 (4 Jul 05 17:59), the ALLPROPS program may interest you.  You can calculate compressibility factors.
DrCaddy (Mechanical),RGasEng (Mechanical)
With reference to
in the range of 3000-5000psi, and room temperature, the compressibility can be approximated in the form
Z=ap^2+bP +c
Substiture into pv=zRT   and solve for v
v=RT(ap+b+c/P)
Referring to my previous posts relating to the integral of v*dP  or integral of  RT(ap+b+c/p)dp
which yields   RT(ap^2/2+bp+c ln(p)     [you must include limits of upstream and downsteam pressures].
If further info is needed contact me at  sailoday_28@yahoo.com
