Charting binary numbers
I have data that is taken at binary states
Colunm A   Colunm B
0000         20mv
0001         40 mv
0010         60 mv
I can't seem to chart this in Excel.
Any Ideas?
Justin
RE: Charting binary numbers
i guess it depends on what you want to show !
i expect that you want to make a scatter plot of the base ten equivalent of column A and chart column B as the y-coord.
or you could plot column A as a "category" using a line chart ... but i think you'd need to have a complete listing of column A (you wouldn't be able to miss numbers), by insering missing numbers if needed (with 0 in column B).
good luck
Create a separate column, and use BIN2DEC function against column A to convert to decimal integers and plot against that set of numbers
TTFN
